Heater not working, Exploding fuses
Old Feb 14, 2012 | 11:56 PM
incognito's Avatar
Question Heater not working, Exploding fuses
Hey guys, I'm new here, my first post and hoping this is in the right spot and I get some good answers.
I have a 2001 tahoe LS , only modification is a flowmaster muffler, other then that its stock.
I went out to the truck this evening , started up and let it warm up, turned the fan speed up and nothing happened, this has never happened, so I tried to change the air location, temp contol and fan speed again, nothing.
So I checked the fuses related to the hvac on the side of the dash, all were fine and looked perfect.
I then checked under the hood, there I found a blown fuse. It was the mini 30 fuse and it was black, so I replaced it with a spare, turned heater on and the new fuse exploded within a second, its not just a blown fuse, its charred black and seemed to have blown very hard.
After that I did not attempt anything else, but for 2 30 amp fuses to blow is such a way, something is clearly wrong.
Any ideas on what I could check or look for ? Everything else on the truck is working fine and as it should, no problems at all, but why this heater/fuse thing came up out of no where I don't know.
Any help would be great, all I've done so far is checked other fuses and all were fine.
I am mechanically inclined, but when it comes to electrical its all greek to me.
What should I do or check ?
Its cold up here in canada, I need my heater back. Lol
Thanks guys
Old Feb 15, 2012 | 8:44 PM
Welcome to the forum... I would try disconnecting the blower motor and then replace the fuse, if it does not blow then the wiring is probably good the blower motor is bad...
Aaron Green
Cobalt
Mar 15, 2015 9:21 PM
scrappt
Nov 22, 2011 2:44 PM
ds76
16
Jun 9, 2010 6:48 AM
mychevyvan
Oct 23, 2006 1:02 PM
drewsm3
Jul 26, 2006 9:22 PM
