Help with 02 suburban over heating and AC
Old May 29, 2020 | 5:28 PM
  #11
Cusser's Avatar
Besides (1) a bad fan clutch, (2) could be entrapped air in the cooling system, or just a bad radiator (even if it was chemically "cleaned"). Could also be bad cap on cooling system, or bad thermostat.
If mine, I'd start by testing (1) and (2).
Old May 29, 2020 | 6:11 PM
  #12
Matthew V's Avatar
shoudnt be a bad radiator i changed that at 215k im going to change the clutch fan regarless since the truck has 226k miles most parts are oringal.
Old May 29, 2020 | 6:12 PM
  #13
Matthew V's Avatar
Originally Posted by subfan597
My '01 Suburban was overheating when AC was on at idle. I'd turn off the AC, turn on the heat with the blower on high and the temp gauge needle dropped back to normal. I suspected the need for a coolant system flush which I did with Blue Devil brand flush treatment. I simply followed all directions on the bottle, let it run for 30 minutes, drained it and filled with tap water and let it idle. Even with no antifreeze in the system and with the AC on parked in my driveway, the gauge stayed put at about 185 to 190 degrees. I ran with that for a bit, drained and filled again, ran that a bit, then drained and filled with Dexcool 50/50. It has not overheated since. Oh, I also took off the upper fan shroud and the bezel or whatever it is above the radiator and sprayed out the radiator fins from inside and out. As for that fan clutch, I too had that replaced some years ago. I'ts been so long (I now have 244,000 miles on it) that I can hardly remember why I did it, but I seem to recall a similar situation with the AC working on and off.
i flushed it 25 k miles ago. New radiator. Going to replace the fan clutch. Due to the High miles of the truck
Old May 29, 2020 | 7:08 PM
  #14
Cusser's Avatar
Change the fan clutch, not the clutch fan !!!
Radiator likely OK as you don't run hot at faster vehicle speeds, air rams through the condenser and radiator then.
Old Jun 2, 2020 | 12:19 PM
  #15
Matthew V's Avatar
Replaced the fan clutch and its still showing the same problems. The radiator i replaced 20k miles ago and flushed the cooling system when i replaced it. Thermostat?
Old Jun 2, 2020 | 12:27 PM
  #16
Cusser's Avatar
Now go to (2). Cap and thermostat are inexpensive. Question: the fan shroud is present and correct type, right??? You are using about 50/50 coolant/water, right? When you changed the radiator at 215K did you get a heavy-duty one, or one for a small truck??
Might be getting to where you visit an independent ASE mechanic to let a second set of eyes look at it.
Old Jun 2, 2020 | 12:31 PM
  #17
Matthew V's Avatar
radiator i got a good big one nothing cheap spent 200 + on it colent is good. Thinking its thermestat since the uper radiator hose it hot to the touch
Old Jun 3, 2020 | 8:54 AM
  #18
subfan597's Avatar
i have a 02 suburban 1500 LT autoride. I have a couple problems hoping you guys can help.
First when the truck is idling the ac starts to blow warm but once im moving it starts to blow cold.
also later today i was stuck in traffic for 30 to 45 min the truck started to over heat once i truned off the ac it was back at normal temperature.
So my question is what is casuing this? I came to the assumption that the thermestate is bad. Due to the two symptoms that its showing but what do you guys think?
The fan clutch and radiator approach didn't help you, but I have a hard time understanding what the thermostat has to do with the AC. I too had an AC problem where it would run cold then hot then cold again until finally one day it would not blow cold air at all. The compressor would run but no cold air. It turned out to be a valve on the high pressure side that had developed a minute leak. Once replaced, the AC blows cold all the time; up till then a Freon charge might last a month or two before it leaked out. They had a heck of a time finding the problem as a result. Yours could be heading in that same direction.
Old Jun 3, 2020 | 9:40 AM
  #19
Matthew V's Avatar
From what i was reading some forums said that thermostate did have something to do with warm air once it started to heat up. How many valves does the suburban have?
should i also replace the high and low? A delco one on amazon is 4 bucks
But would that cause the over heating as well?
Old Jun 4, 2020 | 8:04 AM
  #20
subfan597's Avatar
Default Heating and AC woes
What is going on is two separate issues. Yes, a good thermostat will aid in warm air blowing and help keep the engine from overheating. But where having the AC on will put additional load on the engine resulting in possible overheating, the thermostat, good or bad, should have no affect on whether the AC blows cold or not. Like I mentioned, having that valve on the high pressure side replaced fixed my AC and there has been no problem since, yet up till I did the radiator flush having the AC on seemed to make the engine's cooling ability inadequate. The only fix was to turn off the AC and turn on the heat, after which the temp gauge would drop to where it belonged, about 190 degrees. How many valves does a Suburban have you ask? I am GUESSING one on the high pressure side and one on the low pressure side, but I really have no clue for sure. I just know that what they did worked. I regret to add that when temps hit 97 in my area recently my gauge started climbing again with the AC on at idle. Very disappointing; and all I can think of is maybe my fan clutch is going again...it does have 244,000 miles on it. And being that i did the flush and sprayed the fins out there isn't much else that it could be. I also hear a gurgling sound when I first accelerate after initial start up. It seems to come from the heater core area. I believe the problem is that area is a high point but there is no high point vent to bleed the air out so it just travels through the system till the engine is turned off, where the air finds it way back to that same high point near the core. I bought a Prestone flush kit some time ago with a T shaped piece that you cut into the heater hose near the fire wall. It is for a hose to be hooked up to aid in flushing the engine but it can also be used to burp the air out of the system from that same high point I presume...maybe. The only other thing that might be a problem in our vehicles that I can think of is a vent damper that isn't working properly. Mine seem to work but they seem to be stuck for a second and then open or close loudly. It is quite the adventure keeping this old boat afloat, but I sure like not having payments.
