Help 1997 Suburban trouble codes P340, P1345, P0300
Old Jun 9, 2009 | 11:27 PM
TURBOPOWERED68's Avatar
Question Help 1997 Suburban trouble codes P340, P1345, P0300
1997 Suburban 350 4X4 gave 3 Codes in the following order:
1. P0340:Cam Position Sensor A bank, 1 Ckt Malfunction
2. P1345: CKP/CMP Correlation
3. P0300: Random/Multiple Cylinder Misfire detected, mod $10
Just got the truck
it had both heads cracked So we installed 2 new heads and now it runs worst then when it had the cracked heads on.
HELP<!-- google_ad_section_end -->
Old Jun 10, 2009 | 7:34 AM
MDTAHOE's Avatar
Professional Mechanic
All of the codes could be caused by the distributor being installed incorrectly.
Old Jun 18, 2009 | 6:34 AM
Question
Thanks for the reply <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
What is the step by step procedure to setting the timing on this truck?<o></o>
Thank you very much for your help.<o></o>
<o></o>
David<o></o>
Old Sep 12, 2011 | 10:27 PM
gdw73's Avatar
I got the P0300 code, I am going to replace fuel pressure regulator on my 1997
Old Jan 22, 2012 | 10:46 AM
trevor.klassen@hotmail.com's Avatar
HEY guys I NEED HELP !!!!!!! I have a 1995 tahoe with a 350 tbi. It has 250,000 kms and it runs like crap. It runs better in park then once you put a load on the motor the truck tries to die. It runs alot better when cold and if your driving at higher speeds (thats if it can even get to like 80 kms), and you put the pedle to the ground it sometimes dies or will down shift and try and take off but wont go anywhere. I have un plugged the o2 sensor and no change in running, i have un plugged the knock sensor and no change in running. The EGR is new i have done the distributor, cap, rotor, plugs,wires, coil, tps, map, tbi gasket, checked the fuel pressure its at 7 psi,grinded down the grounds, timed it, checked for vaccum leaks, and it doesnt throw a code. If there is anything else i could try PLEASE let me know. thanks.
Old Jan 22, 2012 | 7:48 PM
What's the fuel pressure supposed to be?
Seven psi sounds low, more like what a mechanical fuel pump delivers for a carburetor.
Old Jan 27, 2012 | 1:04 PM
GDingle's Avatar
That many miles...first stop...timing chain.
UM Rebel
Jan 17, 2016 8:22 PM
4tofloor
Apr 18, 2015 8:57 AM
Ecssound
Jan 23, 2012 5:19 PM
tat2dup81
Sep 28, 2009 6:16 PM
HeyRobi
Sep 6, 2007 8:14 AM
