Help
Old Aug 13, 2012 | 1:45 PM
Parsley's Avatar
Unhappy Help
i have a 2004 suburban. just replaced the rear brake pads, rotors, and also calipers. after doing that i bled the brakes, RR LR RF LF. after that the petal was still very soft. checked for leaks in the lines and the master. no leaks. any suggestions?
Old Aug 13, 2012 | 2:46 PM
kevinkpk's Avatar
Did you bleed the master cylinder?
Old Aug 13, 2012 | 4:18 PM
hicksvilleshick's Avatar
I'm not sure why they needed bled... unless the pedal was mush after the new pads before the bleeding attempt.
so it won't pump up at all? I'm assuming your keeping the mastercylinder full...
I'd say you need to keep bleeding with the info given.
:chug:
Old Aug 22, 2012 | 2:06 PM
Parsley's Avatar
sorry I took so long to reply. I bled them 3 times. the first i bled them air bubbles came out but none the other 2. and yes I've kept the master full. the petal is very soft still, but the brakes work. just when I push the petal it almost touches the fire wall before it finally starts to firm up and stop the vehicle. I've changed the brakes many times on this vehicle and never had a problem till this time.
Old Aug 22, 2012 | 2:35 PM
cowljeeper's Avatar
I would check the rubber lines to the caliper. they could be worn out and expanding. if you go to braided lines the pedel will definitly stiffen up. Also possibly check your brake booster located behind the master cylinder for any wear or damage.
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
