HELP! B1S2 o2 sensor wiring ripped off truck (08 SUBURBAN 5.3)
Old Sep 18, 2019 | 7:20 PM
david gaboury's Avatar
Default HELP! B1S2 o2 sensor wiring ripped off truck (08 SUBURBAN 5.3)
Hey all,
My downstream o2 sensor plug and a couple inches of my wiring harness got ripped off by my 4wd driveshaft (long story ill explain later...).
So now im missing my connector and how to wire it back in!
1. Bought new conn. from Autozone
2. Bought new o2 sensor Bosch 15698
3. Went to wire it back in and did it wrong...
Does anyone have a wiring diagram with colors and voltages i can use to wire this thing back together??
Thanks in advance!
DaveyBoy
Old Sep 18, 2019 | 9:51 PM
Ttt! For a quick response
Old Sep 19, 2019 | 7:57 AM
Go to a junk yard and get a connector from a 08 Suburban with the correct color wire so you can connect it correctly. You can also look at the downstream 02 sensor on the other side to see how it is wired so that you can match that one. Check your fuses, you might have blown one with the incorrect wiring.
Old Sep 19, 2019 | 9:30 PM
Thanks for the quick reply.
Unfortunately no junk yard around me has an 08 and for some reason the 07 is different. Crazy.
Maybe someone could hop under their 08 for me and snap a pic of the drivers downstream o2 plug and harness?
Wicked appreciate it.
Once i get this figured out ill be posting an o2 wiring diagram for everyone else out there cause guess what... In all the world wide google web there doesnt seem to exist one!
Olivia1979
1988 - 1998 (GMT400)
Nov 16, 2017 9:13 AM
mike elder
Aug 3, 2017 6:01 PM
zaden
Oct 13, 2016 3:52 PM
Crabtimus Prime
Jul 17, 2016 7:27 PM
dholling
Nov 1, 2014 12:40 PM
