HELP! Brake system, traction control, and stabilitrake won't turn off!
Old Sep 29, 2015 | 9:15 AM
Rima Hourani's Avatar
Default HELP! Brake system, traction control, and stabilitrake won't turn off!
I have a LS 2008 Chevy Tahoe. My brake system light, stabilitrake and traction control keeps coming on all the time. Sometimes it won't stop dinging while I'm driving. I attached a picture. Can someone help direct me as to how to repair this?
Attached Thumbnails HELP! Brake system, traction control, and stabilitrake won't turn off!-image.jpeg
Old Sep 29, 2015 | 12:20 PM
mulmur1's Avatar
Do you have access to a scanner to check the truck for codes? It would be helpful to know what codes are being stored. I assume that you have checked the brake system to make sure that everything is okay? IE brake fluid level etc?
If you have Onstar and do not have a code reader, I believe that an Onstar rep will also be able to provide you with feedback on what is throwing the error. Also, many of the auto parts stores will read the codes for free.
Also, you may want to check the connection to the brake control module. It is located on driver's side frame rail. If the connector is loose, damaged, or there is corrosion, it will cause problems with the signals.
Good luck with your repair and let us know what you find.
BullDawg30
Jun 27, 2022 2:05 AM
Castellucci77
May 22, 2020 3:26 PM
jniolon
Oct 8, 2012 3:33 PM
Mr. Vann
Nov 25, 2009 7:24 PM
