Help diagnose 1999 Suburban
Old Mar 27, 2023 | 11:36 AM
Velomax's Avatar
Default Help diagnose 1999 Suburban
I have a 1999 Suburban 5.7 L V8 which has been very reliable. It has been running for a while with a soft check engine code P0430. I have changed the oxygen sensors and nothing has changed. Lately it has developed a violent miss/backfire only after warming up and being driven a distance. Battery, alternator, thermostat, distributor cap and crank position sensor have been replaced. What is the next step to figuring this out? Thanks.
Old Mar 27, 2023 | 12:46 PM
Craig0320's Avatar
Could be the fuel pressure regulator going bad. It is located under the upper intake attached to the spider fuel housing where the plug attaches. If you have a scope camera use that to look to the back of the intake signs of leaking.
EMMONS717
Nov 9, 2020 12:17 PM
Darksithlord
Aug 25, 2013 3:31 PM
ChevyBoy17
Feb 13, 2013 8:59 AM
chevysrfoxy
Jan 12, 2008 2:38 PM
