help with high idle
Old Jun 13, 2009 | 3:48 PM
540cosmo's Avatar
Default help with high idle
i have a 95 tahoe 4x4 2 door 5.7 engine i have really high idle when in park around 2000 rpm and in drive around 1100 rpm i have just done wires, plugs,cap,and rotor this made the idle actually increase i have also cleaned the tps and my ses light comes on sometimes at idle but then goes back off any suggestions?
Old Jun 14, 2009 | 6:23 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Start with checking the IAC (idle air control) and make sure it's not stuck open.
Old Jun 14, 2009 | 1:55 PM
540cosmo's Avatar
replaced both iac and tps sensor idle came down to about 1750 at park and 1050 in drive, could it be vehicle speed sensor?
Old Jun 14, 2009 | 7:42 PM
mudmaniac's Avatar
Ride of the Month
May 2009
I don't think it would be the speed sensor, that would possibly effect the shifting but not the idle.
I say it a lot on this forum, but when you removed and replaced the tps, did you check and adjust the voltage signal?
Old Jun 15, 2009 | 9:57 AM
540cosmo's Avatar
update, found problem was throttle body gasket blown,replaced with new now everything is where it should be. thanks mudmaniac for your help!
Old Jun 15, 2009 | 7:29 PM
mudmaniac's Avatar
Ride of the Month
May 2009
Glad to hear it was an easy fix.
in2pro
Dec 25, 2020 11:34 PM
Keeyon77
Nov 16, 2014 6:00 PM
otis_xing
Apr 13, 2013 2:31 PM
420daddy
Apr 25, 2011 2:24 PM
mimaheu
Aug 19, 2008 4:33 PM
