Help ,I need somebody 2001 suburban
Old Jun 15, 2015 | 7:27 AM
NakedByNoon's Avatar
Default Help ,I need somebody 2001 suburban
hello ,
I'm new to the forum and I'm having issues with my burb .
1: I just replaced the transmission from a 1998 due to the other one failing and now my speedo reads what would be 120 and my 4x4 does not engage
2: the ac in the front us warm and the ac in the rear is ice cold
3 : intermittent e brake light and solid abs light .
the truck is an 01 burb 2500 with an 8.1 and a 4l80e as well as a black bear tune. Any help would be greatly appreciated
Old Jun 16, 2015 | 2:03 PM
Scotiapilot's Avatar
Speedo gear needs to be changed or reprogrammed. I think its likely 4x4 wont engage until that's fixed.
Sounds like internal mixer problem, look up cure here.
Old Jun 16, 2015 | 5:30 PM
do you think that will also fix the cruise control ?
Old Jun 17, 2015 | 11:13 AM
Yes, it is speed sensitive
Old Jun 17, 2015 | 12:48 PM
so an update i tested my 4 low and 4 Hi work and my speedo works while in 4wd, its just auto 4wd that does not work and my speedo does not work in 2wd
chapefo
Sep 27, 2012 9:46 PM
rcolon646
Nov 19, 2010 8:48 PM
86kicks
K5 Blazer
Oct 7, 2010 11:55 AM
KRD
Jul 25, 2010 6:11 PM
