Help I'm a parts replacer not a mechanic
Old Mar 2, 2016 | 8:28 PM
Joe Harrison's Avatar
Default Help I'm a parts replacer not a mechanic
So i replaced the fuel pressure regulator on my 99 tahoe because truck was hard to start now that I've done that the motor wont start because the cylinders keep filling with fuel. I've pulled the plugs to drain the fuel 3 times already but it fills right back up when I turn it over a few times I unhooked the battery to see if it would reset. Help losing my mind. Thanks in advance for your time.
Old Mar 2, 2016 | 9:41 PM
which bodystyle 99 new or old ? Engine?
need to know which fuel injection system its has multi port with a spider or sequential injection...diagnosis is different as the systems are different.
Old Mar 3, 2016 | 8:17 AM
Default Sorry didn't answer sooner
[QUOTE=tech2;317658]which bodystyle 99 new or old ? Engine?
need to know which fuel injection system its has multi port with a spider or sequential injection...diagnosis is different as the systems are diffedifferent.
99 5.7 vortec. Spider injection
Old Mar 3, 2016 | 5:07 PM
it's a 99 with a 5.7 vortec spider injection old body
Old Mar 3, 2016 | 8:31 PM
never worked on the port injection so can't help. the new fpr is in the spider I assume. sounds like the poppet valves/injectors are stuck open...would high fuel pressure cause that?
Old Mar 4, 2016 | 8:20 PM
cleveland63b's Avatar
not super familiar I've only had my hands in the spider system a few times but if I remember right the pressure is what opens them, I don't remember the regulator being separate but I could be wrong. might have to do a little research
