help needed with codes p0308 p0358/and coolant leak
Old Apr 21, 2012 | 12:43 PM
mutineer's Avatar
Default help needed with codes p0308 p0358/and coolant leak
I noticed about 500 miles ago that the coolant was low so I added some now it's low again. I didn't see any leaks, I then sarted to get codes p0308 (cyl 8 missfire) and p0358 (ignition coil H pri/sec circuit) also an unrelated code, I think, p0455 (evap systems leak gross) My thoughts on this were intake leak into # 8 cyl ? I checked # 8 plug and it looks fine. just checking to see what everyone else thought before I started this job
Thanks much
Old Apr 21, 2012 | 5:10 PM
mutineer's Avatar
ok quick update replaced coil on number 8 and that fixed miss ordered evap can should fix p0455 now still have to find coolant leak
Old Apr 22, 2012 | 7:19 AM
Welcome to the forum,
Do you have the rear AC ? if so check at the rear quarter panel behind the tire for any leakage.
riflerack31
Aug 2, 2014 7:38 AM
NJ_Tahoe
Sep 26, 2013 9:54 AM
Eric Sherden
Sep 24, 2013 1:21 PM
95wt
May 30, 2008 3:07 PM
AAHTahoe
Jan 15, 2008 9:09 PM
