help please won't turn over
Had my rear fuel lines fixed by a mechanic drove 14 miles and my tahoe sputtered and died now it won't turn over and the starter just goes bang, oil pressure was fine and the temp was never above normal, I towed it back to the shop and they tried to say they think it seized. Please help with any input. Second opinion by another mechanic based on my description says there is no way it seized.
Well second mechanic had now assessed my vehicle and it is not seized. number three cylinder was full of gas so it was hydrolocked. He that'd the pressure and said it wad priming at about 100 psi which is what files the cylinder. He is now checking the work they did on the fuel lines in the back to see if they pinched the return or something but all in all good news is that the engine is not siezed.
So the mechanic found that the shop had pinched the fuel return line which caused the pressure to rise over 100 psi which in turn blew the poppet valve on my spider injected he explained this to the previous shop with some evidence and they promptly fixed the problem at no cost.
