help with running temp info please
My 1996 tahoes temperature seems to fluctuate from one line to another consistently while driving in all conditions, it never overheats and only fluctuates by about 20 degrees but I'm just wondering if it is normal or not, so far I have replaced the radiator(was leaking), the thermostat, and the heater selector switch. Please help as I would really like it to stay at a more consistent spot
Yeah, I used to drive a Honda Accord and I was always nervous of it over heating cause the head gasket go so easily. It makes me watch the temp gauge to much sometimes I think.
Temp ranges as described occur in ALL coolant systems in our vehicles.
This occurs most often when we stop suddenly, and the lack of circulation drives the temperature up briefly. Other frequent excursions of temp are experienced in varying speed traffic. This is a normal and unavoidable situation.
Most times, the manufacturer installs attenuation in the circuitry of the temp sensing system. What this does is, not allow the reading of the variation of temperature to move the dash gauge quickly. Therefor not causing the operator cause for concern, as you have experienced.
There could be several reasons why the attenuation capability in your vehicle has increased in sensitivity, but, all in all, the excursions you have described are not dangerous, but normal.
