Last edit by: IB Advertising
Browse all: Engine and Powertrian
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Throttle Position Sensor (TPS)
HELP - Service Stabilitrak & Service Traction Control
The traction control and other warnings can signal many things....
It could be a throttle body issue, or throttle body wiring, or an AFM issue if you are consuming a lot of oil....
Have some basics checked like fuel pressure, compression checked on all cylinders,inspect all plugs for oil fouling, have the alcohol reading in the computer checked, consider getting fuel from another station...
I took my Suburban to have the tires rotated. As soon as the job was completed and I drove away the traction and ABS warning lights came on!
Drove for a few miles hoping that the codes would clear and they did not. Called the service center and they said it had nothing to do with them.
Seeking some advice, no other issues with 63,000 mile Suburban.
Amber N.
Chevrolet Customer Care
+1 what trainwreck91 said, a wheel speed sensor most likely got knocked or pulled loose... and my 2 cents, don't ever go back to who did your tire rotation, they probably did something and aren't willing to acknowledge it... knocking the sensor or connectors is something that is very easy to do when working in the wheel wells...
It was most likely a rambunctious monkey doing the rotation as quickly as possible to get customers in and out...
My suburban started having problems two weeks ago. First time stabiltrack light came on and the engine wen into protection mode can only drive it at 5 mph. Went to shop no codes nothing they could do. Wednesday Same issue but light went out shortly after restart Thursday same issue but now the stabiltrack light is on and I cant go over 5mph.
