Old Jul 24, 2015, 4:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
HELP - Service Stabilitrak & Service Traction Control
Old Sep 15, 2014 | 8:56 AM
  #181
thumperyz's Avatar
Default Again!!!
So I let them put the 2nd steering sensor in for 465.00.I go to pick the truck up and on the way home yet again I get the same message, service stabiltrak!! I go the the dealer because they are the ones with the fancy code reader and such, but this is getting old. Fast!!
Old Sep 15, 2014 | 12:00 PM
  #182
Official GM Rep
We understand your frustration, thumperyz. Please private message us your VIN, mileage, full contact information and dealership name if we can try to assist towards a resolution. We hope to hear from you soon.
Amber N.
Chevrolet Customer Care
Old Sep 16, 2014 | 12:35 PM
  #183
thumperyz's Avatar
Thank you,they called this morning and said they had to replace the connector and that there would be no charge.So lets see if this fixed it and go from there!
Old Sep 16, 2014 | 5:48 PM
  #184
Official GM Rep
That's definitely good news, thumperyz! Let us know how everything turns out.
Amber N.
Old Sep 20, 2014 | 2:17 AM
  #185
alabang tahoe 08's Avatar
2008 Tahoe, 5.3, Black, red sheepskin seat covers, DD, CEL on for past 2 years (right after Dynamaxx+Borla w/K&N install) Perfectly maintained = Runs awesome.
last week I got a surprise.
Service Stabilitrack
ABS Light
as it happens, this was after carefully changing my Swaybar end link bushings.
Just in case, Last night I pulled the wheels, checked the wheel speed sensor cables, look perfect, OEM like.
This morning, plugged in my ODB2 reader, po121 TPS and po496 EVAP, reset, CEL now off, no change to Stabilitrak/traction/ABS warning/ lights.
Need help ! ! Big road trip starting on Tuesday.
Old Sep 22, 2014 | 7:12 AM
  #186
SOLVED!....?
took it to the local Chevy guys and paid $50 for a scan.
they said the left rear wheel speed sensor cable needed replacement.
took it home (they didn't have any in stock of course). uplugged it (seemed kinda loose) replugged it in and wala, no more error.
will let you know if it holds.
over and out
- G
Old Sep 24, 2014 | 9:54 AM
  #187
ram49's Avatar
Default stabilitrak
I see that someone mentioned a speed sensor cable for the stabilitrak problem. Where is this located ?
Old Sep 25, 2014 | 3:55 AM
  #188
I'm no expert but I think I can point these out.
There are 4 cables, 1 each is mounted adjacent / behind each of the 4 brake rotors. The cables are black, dirty, about the size of a cheap power cord.
They are a lot smaller and flexible than the brake line in the same region.
One end of the cable is fixed into the wheel area by a torx head screw.
The other end goes up toward the chassis (behind some plastic in the back, easier to see in the front) where you will find a snap type connector.
I found my right rear connector a bit loose, got it apart, snapped it back and the error disappeared without an ODB2 reset tool
good luck!
Old Sep 25, 2014 | 7:45 PM
  #189
nukstr's Avatar
Default Gm called me after i e-mail, & said they will fix it
Okay, I wrote this email to GM after they confirmed I actually spent over$12,000. Anyways they called and said GM is escalating my case Number to senior tech and will work will my local GM service department and said GM would fix it at no cost to me. I will keep you updated on if they will fix it or they just blowing smoke. Here's the E-MAIL I sent:
SERVICE STABILITRAC & SERVICE TRACTION CONTROL LIGHTS ON TAKING DEALERSHIPS EVERY 4 WEEKS TO REBOOT OR RESET COMPUTER, 4 DEALERSHIPS DO NOT KNOW WHAT THE PROBLEM REPLACEMENT TRANSMISSION,BCM,HUBS,BATTERY, SENSORS, GAS SAYS ETHANOL OVER 40%, BUT FILL UP AT NON ETHANOL GAS STATIONS? ETC. AFTER $12,000 SPENT - STILL SERVICE STABILITRAC & TRACTION CONTROL LIGHTS COMES
Jim (last name)
2007 GMC YUKON SLT
(address)
(Phone Number)
Dealerships AUTONATION - SPOKANE VALLEY, WA
CAMP CHEVY-SPOKANE, WA
LIBERTY LAKE, WA
DAVE SMITH, KELLOGG, ID
Old Sep 25, 2014 | 8:33 PM
  #190
Jim (last name)
2007 GMC YUKON SLT
(address)
(Phone Number)
LIBERTY LAKE, WA
$12k? holy cow!
I paid about $50 in local money for a "scan" that showed the right rear speed sensor was not working. I had to pay more for them to replace the part but they didn't have any stock. I brought it home and played with it, seemed to fix it.
is your ABS light on?
