HELP!! :Speedometer works when it wants to!!!
Old May 3, 2009 | 10:09 AM
robertmack83's Avatar
Default HELP!! :Speedometer works when it wants to!!!
My speedometer works most of the time but sometime is does not. I have replaced the speed sensor that goes in the tp of the transmission helped for a little while , but now it is doing it again. Does anyone have any suggestions on what to try next?
Old May 3, 2009 | 10:29 AM
Mike Sigmond's Avatar
ROTM Coordinator
Welcome to the Forum,
What year & model are we talking about here? There have been some guage cluster recalls recently. I have an 02 silverado, they replaced the whole cluster about 6 months ago. I had the same problem and with my speedo, tach & fuel guage.
Old May 3, 2009 | 3:41 PM
its an 04 Lt 4wd
Old May 3, 2009 | 4:32 PM
ROTM Coordinator
It should be under warranty or possibly a recall, Id check with the dealer, My Tahoe as well had a guage cluster problem and they repaired it too free of charge.
Good Luck!
Old May 13, 2009 | 3:26 PM
CAROVA's Avatar
JUST FIXED MINE!!!!!!!!!!!
symptoms
no speedomoter, not shifting out of first, abs light on
solution
cleaned front speed sensors (got rid of abs light)
replaced transfer case speed sensor (now it shifts properly)!!!!!!!!!!!!!
$165 for part from dealer. no other choice where i live
Old May 13, 2009 | 3:56 PM
Mud_Truckin's Avatar
I would also check the female end of the cable, sometimes, depending where you live salt and dirt from the road works its way in there and will cause it to have a poor connection, just a thought for a freebie
Old May 16, 2009 | 2:03 AM
ROTM Coordinator
I got a reply back in a PM , I figured it post it for an update.
Originally Posted by PM from robertmack83
Thanks for telling me about the recall. I called the dealer and mine was one of the ones that fell within the recall so they fixed it for free. Everything is good to go now.
Old May 17, 2009 | 8:24 AM
the dealer replaced the whole gauge cluster thanks for the help
Old May 17, 2009 | 11:58 AM
ROTM Coordinator
Glad it worked out for you! Cool, your Hoe looks like my 04, mine is black too! minus the 4X4, I am jealous.
Old May 17, 2009 | 7:48 PM
want to lift it but the prices to lift it because it has independent suspension are up there
