help - Tahoe started jerking when in reverse
Old Aug 27, 2009 | 8:54 AM
gcr2532's Avatar
Default help - Tahoe started jerking when in reverse
I have a 2003 Chevy Tahoe 2wd with 115K miles. When I put it in reverse, it will start backing up for a few feet and then you feel a jerk. The first time it happened I thought I backed into something. It almost feels like a u-Joint slipping, kind of like a clunking sound. But if it's a u-joint, should it also clunk when I put it in drive too? If not the u-joint, any other ideas what could be the culprit?
Old Aug 27, 2009 | 10:13 AM
Welcome to the forum
That or the rear differential, locker could be hanging up, and something to consider is the rear brakes more so on drums then disc but something to consider...
Old Aug 27, 2009 | 11:40 AM
SabrToothSqrl's Avatar
Default clunk
my 95 would 'clunk' into reverse... always sounded bad, never affected anything with 280,000 on the odo...
if you drop a u-joint you will know soon enough
they are easy to replace though and there are only 2 on the back shaft... it's an ok place to start for $30 or so...
Old Aug 27, 2009 | 8:54 PM
chrisbmo2000's Avatar
sounds like the tranny may be low on fluid....if the fluid is fine have someone check the line pressure on the tranny...... it sounds like what you have is what is called a reverse double engagment which is usually caused by a low fluid condition or low line pressure.
Old Aug 27, 2009 | 9:11 PM
MDTAHOE's Avatar
Professional Mechanic
One way to prove or eliminate the u-joints is to pull the shaft out and move each joint in all directions they should move smoothly and freely.
Old Aug 29, 2009 | 12:06 PM
gcr2532's Avatar
Thanks for the post, I'll take a look this weekend and post the results.
Old Aug 30, 2009 | 9:23 AM
remember to block the wheels and work on a flat/level surface, once you take the drive shaft out the tranny no longer keeps the rear wheels from free spinning and the truck from rolling away and or over you....
caldwell33
Mar 26, 2015 8:05 PM
Patrick Ryan
Mar 20, 2014 10:07 PM
KitaKaT
May 13, 2008 2:43 PM
chrisrud15
Oct 25, 2006 2:25 AM
