HID headlights won’t stop flickering
I have a 2015 Chevy suburban LT I’m having a lot of issues with fixing the HID’s they won’t stop flickering I have checked all the fuses, changed the ballast, purchased expensive HID’s and still have the problem. Please help
If its an aftermarket hid system....do you have an antiflicker module?
If the truck came with halogen bulbs from factory the bcm pulse width modulates voltage to the headlights. When you change to aftermarket hid s ystem....the pwm voltage won't operate the system properly.... you need af modules
When is it happening? Whenever the lights are on, or only when in motion? Does it matter if you turn the switch to manual instead of auto? Dims/brights/both? Turn signals/flashers on or off? Brake pedal being applied? Does it stop or start when turning?
You may need to have a shop scan for body codes or get a device that can do it for you, such as a dongle and phone app.
Doc Savage
2014 - 2018 (GMT-K2)
November 9th, 2022 11:27 AM
