High Oil Pressure
Old Apr 13, 2008 | 7:11 PM
ot01314's Avatar
Default High Oil Pressure
I have a 2003 Tahoe the oil pressure gauge is pegged at 80, the truck usually runs with it between 40 and 60. It seems to be running fine and no other warning lights or gauges out of the normal range?
Old Apr 14, 2008 | 3:33 AM
SAUDILTZTAHOE's Avatar
Default RE: High Oil Pressure
Bad oilsending unit
Old Apr 14, 2008 | 7:27 AM
ZX1100F1's Avatar
If the needle is does not return to zero when you shut the key off then the stepper (indicator needle) motor in the cluster is a likely suspect otherwise the sender.
outdoordb
Aug 19, 2020 3:26 AM
not_a_car_dude
Sep 15, 2013 7:41 PM
RTR09
Dec 8, 2009 4:52 PM
WorkerB
May 29, 2008 2:24 AM
Gymnutz
Mar 25, 2007 5:45 PM
