High Oil Pressure !!! help me
Old Oct 3, 2016 | 4:25 PM
  #11
kevinkpk's Avatar
No, I think it needs replaced
Old Oct 4, 2016 | 6:13 AM
  #12
rafamiott's Avatar
I will replace him. Is this a common problem ?
Old Oct 4, 2016 | 7:19 AM
  #13
If the sensor is bad it needs to be replaced. Cleaning will usually not help. Check the wires going to the sensor. Being loose or corroded will make a bad connection and cause problems.
Old Oct 4, 2016 | 7:34 AM
  #14
rafamiott's Avatar
All right guys, i will put a analogic measurer to check the real pressure and buy a new sensor.
I have almost certain the sensor is bad, because the pressure hit the max and the oil does not leak
Please follow the thread because i will order the sensor from EUA and perhaps could take so long.
I thank you so much for the help. If you need som help with 1.0 engines the brazilians is the best. hahaaahah
Old Oct 4, 2016 | 5:50 PM
  #15
kevinkpk's Avatar
Replace it!
