Hitch problem
Old Nov 14, 2014 | 1:16 PM
stayathomedad's Avatar
Default Hitch problem
I have an 04 suburban that I'm trying to put a hitch on and am having problems with. It is a curt hitch, there are 4 bolts into the frame and 2 into the bumper. The frame bolts went in with no problems, it's the bumper bolts. I can't get them in. I've tried pb blaster, wire brushing the inside as much as possible, no luck. My next steps are to run a tap through in hopes of clearing the rust out or welding it on.
Any other ideas or suggestions?
Old Nov 14, 2014 | 4:21 PM
Its possible the thread is different then the bolt supplied, if you have a set of taps you might want to use those to identify the thread...
Though re-tapping to the bolt in hand is probably viable as long as your have sufficient thread to securely hold the bolts in place...
Old Nov 14, 2014 | 9:38 PM
for some reason the bumper fastener threads crud up. I squirted trans fluid onto the threads and let it soak in for 24hrs and then repeated. I soaked the bolts in a jar of trans fluid for a couple days also. I hand started them and worked them in and out with a impact wrench.
get all the bolts started before tightening any up.
Gman
Nov 22, 2006 8:56 PM
vyslouzil
Sep 25, 2006 11:23 AM
pateng
May 11, 2006 10:23 AM
bigtrucks
Jul 5, 2005 10:59 PM
