Hope I'm Posting This Correctly for 93 Suburban
Old Mar 31, 2016 | 7:44 PM
dm464's Avatar
Default Hope I'm Posting This Correctly for 93 Suburban
I have a 93 Suburban with wiper issues. When I got it, the wipers would not work. It had sat for about 3 years. The fuse was good. I had power at the fuse block. I had power at the motor plug. Bought a new motor but still no wipers. So I checked ohms at the motor plug and had high ohms in the delay setting and the low setting so I assumed the multi function switch was bad. I replaced the switch and turn signal lever arm but still no wipers. Does anyone have any suggestions on something else I can check? Thanks for any replies.
Old Mar 31, 2016 | 11:00 PM
Rednucleus's Avatar
I remember needing to change the module mounted on the firewall behind the distributor on our 93
Old Apr 1, 2016 | 6:30 AM
a55bruce's Avatar
Check/clean the ground connection (black wire)
Old Apr 2, 2016 | 10:14 AM
Yep, that is what I had to do on my 93 Stepside....if I recall it was relatively cheap and easy...
