how to change driver settings
Old Jan 14, 2016 | 9:17 AM
dave110's Avatar
Default how to change driver settings
Hi all. Got a new to me 03 Tahoe. It's a pretty basic one which suits me fine. I don't have the EVIC but whenever I start up I get a DRVER 1 on the odometer readout. That leads me to believe I can change some settings. I would also like to disable the auto lock/unlock door feature as well as the horn beep when locking doors. Owners manual is no help. Is there a way to do this on mine?
Old Jan 23, 2016 | 12:49 PM
dave110's Avatar
Anyone ever have this?
Old Jan 24, 2016 | 1:58 AM
intheburbs's Avatar
Well, the auto lock programming is on page 2-10 of your owners manual.
Programmable Automatic
Door Locks
if your vehicle has power door locks, it is equipped with
a feature that enables you to program your power
door locks.
Your vehicle left the factory programmed to
automatically lock all doors when the vehicle is shifted
out of PARK (P), and all doors unlock when the
vehicle is shifted into PARK (P). You can set the
automatic door lock feature to unlock the doors you
select once the vehicle is in PARK (P).
The following instructions detail how to program your
door locks.
To enter the program mode you need to do the
following:
1. Beginning with the ignition in LOCK. Pull back on
the turn signaVmultifunction lever all the way
toward you until flash-to-pass is activated, and hold
it while you perform the next step.
2.
3.
Turn your key to RUN and LOCK twice. Then, with
the key in LOCK, release the turn
signaVmultifunction lever. Once you do this, you will
hear the lock mechanism lock and unlock.
You are now ready to program the automatic door
locks. Select one of the following four programming
options and follow the instructions. You will have
thirty seconds to begin programming. If you exceed
the thirty-second limit, the locks will automatically
lock and unlock to indicate you have left the
program mode. If this occurs, repeat the procedure
beginning with Step 1.
You can exit the program mode any time by turning the
ignition to RUN (the locks will automatically lock and
unlock to indicate you are leaving the program mode). If
the lock/unlock switches are not pressed while in the
programming mode, the auto lock/unlock setting will not
be modified.
The following is a list of the available programming
options:
e
e
e
All door locks/Only the driver’s door unlocks:
Press the lock side of the power lock switch on
ihe door pmei G W ~an d then the unlock side once
All doors IocWAll doors unlock: Press the
lock side of the power lock switch on the door panel
once, and then the unlock side twice.
All doors IocWNone of the doors unlock: Press
the lock side of the power lock switch on the door
panel once, and then the unlock side three times.
No doors IocWNone of the doors unlock: Press
panel twice. This turns off the automatic lock
feature.
For more information, see your dealer
You cannot change the horn beep when locking the doors.
Old Jan 24, 2016 | 8:25 AM
dave110's Avatar
Thanks a bunch! I must have overlooked that in the manual. I looked for it in the index and missed it. I'll give this a try
