How do I fix camshaft position correlation trouble code
Old Mar 6, 2024 | 2:54 PM
jbl15's Avatar
Default How do I fix camshaft position correlation trouble code
2008 Suburban
Having an issue with my suburban, it showed a p0016 crankshaft position - camshaft position correlation bank 1 sensor A code, changed the camshaft and crankshaft position sensors and tried to perform a ckp relearn, now showing a p0016 ckp-cmp symptom 00 current dtc not passed since dtc cleared, test failed since dtc cleared, test not passed since power up, current dtc since power up on the snap on solus ultra I'm using goes through everything until I try to perform the tests and says malfunctions present and will not let me perform the test after going through everything again and retrying. Wondering what my next step should be, I have not gotten into the wiring yet to inspect/scope. Ran well more so at interstate speeds than it ran bad at lower speeds, I know what those issues are for the most part, just lacking the funds to do the dod/afm delete and at 268k miles seems silly to get into all that, instead I'm looking for a lower mileage engine to replace it with. Thanks in advance!
phness
Avalanche
Sep 25, 2025 4:05 PM
sierranm89
May 18, 2017 3:18 PM
Wesley Garibay
2007 - 2013 (GMT900)
Feb 6, 2017 11:15 PM
Burdell
Jun 2, 2015 4:06 PM
Yogi
Dec 3, 2014 12:07 AM
