Old Jul 22, 2015, 10:31 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
how do i know which brake booster my '83 suburban has?
Old Oct 22, 2012 | 4:50 PM
bwh998's Avatar
Default how do i know which brake booster my '83 suburban has?
hi, i have a 1983 gmc suburban 2wd with the 5.7, just got it today.
the brake booster is bad on it and when i called advance to order the new one they told me that there were 2 different brake systems for my truck and i needed to know which one i had.
they said there should be a sticker in the glove box with that information, which was missing from mine.
is there any other way to figure out which booster i need to order?
Old Oct 22, 2012 | 4:58 PM
kevinkpk's Avatar
Is there a part number on it?
Old Oct 23, 2012 | 7:35 PM
15 Year Member
Give your VIN to your parts dept. I think they can ascertain what you have.
Old Oct 23, 2012 | 7:48 PM
bwh998's Avatar
i did some more research today and think i figured it out, for my application there was a jb5 or a jb7 brake system available, or at least, that's what's available from advance. they are interchangeable but you have to swap the master too. looks like the jb7 is the heavy duty one.
JB5= 6400lb. disc 11.86X1.29 / drum 11.15X2.75 Vacuum-Double Diaphragm
JB6= 7200lb (K20 and others)
JB7= 8400lb. disc 12.50X1.54 / drum 13.00X2.50 Vacuum-Double Diaphragm
JB8= 10000lb. disc 12.50X1.54 / drum 13.00X3.50 Hydraulic-Hydro-Boost
above is what i pulled from a google search, i wonder if the larger rotors and calipers can be interchanged also...
Old Oct 23, 2012 | 9:18 PM
GMcerttech's Avatar
you can look at the codes in the glove box if it still has the sticker in there. if you have a hydro booster then youll have power steering lines going to the booster. for the vacuume booster itll have one vacume line going to it
silverado 1500 2001
Sep 3, 2014 1:03 PM
kansfan48
Jan 19, 2014 11:51 AM
DMaxEnvy
Apr 17, 2011 11:40 AM
rif
Jun 13, 2007 9:12 AM
BinkysDad
Oct 24, 2006 11:32 PM
