How do you remove z71 side moldings??
Old Feb 24, 2010 | 12:53 PM
Keyes21's Avatar
Default How do you remove z71 side moldings??
I have a 03 tahoe, wondering if theres an easy way of removing the side moldings that are grey, around the wheel wells and by the step bars, can anyone help me out??
Old Feb 24, 2010 | 11:24 PM
Welcome to the forum.
I believe they are held on w/ 3M body tape which means that you can just pull them off. The hard part is getting the residue off. Try Goo Gone, WD-40, or DesolvIt. Check it first in a hidden area to make sure it doesn't harm the paint.
Old Feb 25, 2010 | 7:49 AM
PastorK's Avatar
If it's anything like my suburban, the Goo Gone doesn't work. neither does wd40. I was told to go buy one of these.
http://www.tcpglobal.com/autobodydep...temno=MMM+7498
Old Feb 25, 2010 | 11:57 AM
cam3439's Avatar
Those are awesome. I use to use those to remove decals from Semi-Trucks. That'll be the fastest way to remove the left over glue, but you'll need a decent rpm tool. I used an air tool for this wheel. And the wheel usually lasts quite a bit, it's cleaner, and probably also safer for the paint. Don't let the wheel sit in one area too long while rubbing against the paint, for removal, with a higher rpm tool. You don't need much to remove the glue with this wheel.
Old Feb 25, 2010 | 5:37 PM
Keyes21's Avatar
yeah i was thinking the samebut ive been told theres brackets around the rear wheel well and was wondering if there is or not?
Antrell
Feb 16, 2012 6:09 PM
treetop
Jan 4, 2008 5:06 PM
treetop
Jan 4, 2008 5:04 PM
73shark
Aug 29, 2006 2:10 AM
