How much boat can '07 Tahoe tow?
Old Jun 27, 2007 | 2:09 PM
  #11
haidangwa's Avatar
Default RE: How much boat can '07 Tahoe tow?
Great tips, Steve and ZX. My '07 is a 5.3L 4wd with3.73 diff and no tranny cooler yet, but I plan on adding one before doing any serious boat-towing. Now, I know what range of boat to be hunting for.
Old Jun 27, 2007 | 3:25 PM
  #12
MalibuMaxxSS's Avatar
ORIGINAL: ZX1100F1
ORIGINAL: MalibuMaxxSS
max gross on a tahoe is 7700lbs....if your boat is over that you CANT tow it....easy and intellignet enough for you....
Maximum trailer weight that an 07 Tahoe can tow is 8,200 lbs for a 4X4 w/5.3L and 4.10 gears.
This boat is well over this rating.
Typically a modern 26" run-a-bout on the trailer with fuel and gear would be the max recommended trailer load however; some boats are heavier than others so it's always a good idea to take the trailer to a truck stop and weigh it on a certified scale for safety sake.
And as always the biggest problem is not being able to move the load it is being able to stop it and control it.
A suburban can tow up to 8100lbs...Tahoe not so much
07 Tahoes equiped with 3:73 is 7000lbs and 4:10 is 7700lbs.........like I said a suburban can tow 8100 with 4:10 but not the Tahoe
you could go 2500 but they only come in Suburban as well but will tow 9500 lbs
Old Jun 27, 2007 | 3:47 PM
  #13
ORIGINAL: LT4Steve
....The RV guys know all of the practical considerations of serious towing. Spend an hour on a couple of their forums and you'll understand why we are(the responders here) not encouraging. And no one has even mentioned what this'll do to your transmission.......with or without a cooler. How about your differential? It absolutely needs to be 3.73....4.10 would be better. I'm currently installing a 102 sq. inch stacked plate transmission cooler on my '03 LT, 5.3, 3.42 2WD. This is in preparation to tow a 4,500 lb. open car trailer (loaded). I'm installing a trans. temp. gauge with sending units at the converter and on the output side of the cooler. With a two-position switch, I'll be able to measure what the cooler is doing as well as temp. as it exists the converter.
As before, good luck.
curious if you were towing a trailor and knew it why would you get 3:42 in your tahoe??
Old Jun 27, 2007 | 5:09 PM
  #14
ZX1100F1's Avatar
Well I'm not going to argue with you other than to say: you don't know what you are talking about and every tow rating you posted is incorrect.
2007 Tahoe tow ratings are as follows:
2WD / 5.3L/3.42 gears Max Tow Rating of 6,500lbs
2WD / 5.3L/3.73 gears Max Tow Rating of 7,500lbs
4WD / 5.3L/3.73 gears Max Tow Rating of 7,200lbs
4WD / 5.3L/4.10 gears Max Tow Rating of 8,200lbs
The very most that any 5.3L equipped Suburban can pull is also 8,200lbs but for a 2WD 4.10 equipped unit.
The 2500 Suburban can tow up to 9,700lbs for a 2WD and 9,400lbs for the 4X4 with 4.10
Old Jun 27, 2007 | 5:49 PM
  #15
we must be reading different book then cause the 4 on my lot wont pull that....and all the books say teh same...
5300 V8 3.42 2wd 6200lbs
3.73 2wd 7200
5300 v8
extended model....suburban 3.73 7100lbs
4.10 8100lbs
6000 V8
extendend models suburban 4.10 8100lbs
FOR 4WD
5300 V8 3.73 6700lbs
4.10 7700
5300 v8
extended model....suburban 3.73 7000lbs
4.10 8000lbs
6000 V8
extendend models suburban 2500 4.10 7900lbs
According to GM trailor tow manual....
Old Jun 28, 2007 | 8:42 AM
  #16
ZX1100F1's Avatar
Ah OK,
You're using an old or bad pub.
This guide is the most current and correct.
http://www.chevrolet.com/trailering/...de_Catalog.pdf
Old Jun 28, 2007 | 10:27 AM
  #17
LOL ya I see that now I checked into in some more, it is an old pub for sure, you are correct....my bad....man all this time Im telling people 7700lbs.........oh well they wtill bought them, have to call them and tell them.....
Jspinner4
Sep 9, 2014 9:30 PM
BrandanDeMamp
Apr 8, 2014 7:22 PM
bamafutbal
Jan 24, 2011 3:50 PM
grandcas
Mar 7, 2010 9:23 PM
