How much can I lower my tahoe.
I have an 07 Tahoe 305/35/24 tires on 24 inch rims. Wondering if I can Lower it or Should I just Lower the back. Front tires touch only when turned all the way either way.
i am running the same tire and i used the mcguaghy's kit. 2/3 drop with spindles in the front and coils and shock extenders in the back. worked great, looks great and retained a great ride qaulity!
the wheels are made by ARMANO model: FERRAGAMO 24" with a +35mm offset. for tires i went with toyo proxes s/t (everyone says the ride quality is much better with this tire). picked up the wheels and tires together and got the shop to throw in a set of wheel locks and got them to take out my air pressure sensors from the factory wheels and pop them into the new set! got the whole deal mounted balanced for around $3450 out the door.
Do you suggest a 295/35/24 tire with the 2/3 kit from mcgaugdy. I just lowered my LTZ with the 2/3 kit and im looking for a 24" Tire/Rim combo and i dont want any rubbing issues. Also what backspacing i need for the wheels?
BrandanDeMamp
April 8th, 2014 7:22 PM
grndslm
April 24th, 2013 11:21 AM
