How to troubleshoot 2001 Tahoe after running out of gas
Old Feb 18, 2017 | 9:51 AM
David De La Campa's Avatar
Default How to troubleshoot 2001 Tahoe after running out of gas
My Tahoe won't start after putting in two gallons of fuel, how do I troubleshoot?
Old Feb 18, 2017 | 11:55 AM
Turn on your key to the run position and wait 10 to 15 seconds and let the fuel pump prime the system. Then try and start it. If that doesn't work, spray some starter fluid or gas into the throttle body, if it runs for a few seconds you need a fuel pump.
Old Feb 19, 2017 | 2:20 PM
bigava@comcast.net's Avatar
Is the vehicle on flat level ground? If it is not level, two gallons may not be enough for the fuel pump to pick up. Oldchevy post sound like good advise too.
Old Feb 21, 2017 | 12:59 AM
intheburbs's Avatar
Are you sure you ran out of gas, and that it's not a dead fuel pump? They are notorious for failing every 100k or so miles.
Old Feb 21, 2017 | 12:59 PM
Gravydog316's Avatar
If you let the fuel level get too
low, the pump could burn out. (the gas in the tank keeps the pump cool)
...just fyi
