How to turn off the Easy Exit option
Old Mar 30, 2017 | 5:21 PM
Ellie's mama's Avatar
Default How to turn off the Easy Exit option
I have a 2014 Tahoe and I would like to turn off the Easy Exit option. I changed it to Door button only and that seemed to work but when i come back to the Tahoe the seat is moved back.
Old Apr 1, 2017 | 7:13 AM
intheburbs's Avatar
It might not be the easy exit option.
The truck also has an option to recall memory seating for the two different key fobs. If you use memory position one, but have (what the truck sees as) key fob 2, it'll be moving to memory position 2 when you unlock it. Try the other key fob and I'll bet you $1 the drivers seat doesn't move.
You can disable this feature in the DIC as well, if you're the only driver.
