HVAC issues 04 Suburban
Old Jul 25, 2023 | 6:41 PM
Viejito's Avatar
Default HVAC issues 04 Suburban
Hi All. My 04 Suburban with a climate control system is giving me fits. I've tried a couple of Dorman new digital and OEM original reman (in the car now). The system at times blows hot air because its not activating the compressor.
Dorman says the climate control module does not talk to the compressor, but rather communicates with the ECM and the ECM in turn activates the compressor. If thats the case, then would the ECM log the command from the hvac module if the compressor didn't activate? Or alternatively, if there is no ECM code, then there was no command from the climate control module. Everything else in the truck is fine. If it is a problem in the ECM can that be corrected or do I need to replace the ECM with a reman? Thanks
usmarine0905
1988 - 1998 (GMT400)
Oct 20, 2022 6:24 PM
Sam Franklin
Apr 9, 2021 1:24 PM
Atalanta
Sonic (Aveo)
Apr 13, 2017 11:25 PM
dspud2006
Feb 18, 2011 10:47 PM
la4by4
K5 Blazer
Sep 21, 2007 10:24 PM
