I am sure most know this but I am new
Old Feb 15, 2014 | 4:19 PM
Desert Gringo's Avatar
Default I am sure most know this but I am new
to the world of bowties... I bought a 2002 chevy LS Suburban 4x4 owners book calls for a pf59 oil filter and 6 qts of oil with a new filter, I look online it shows a pf46 a shorter filter, so I bought it and did the oil change, now do I still use 6 qts? or 5 , or even 5.5 qts. of oil?
thanks
feels like a dumb question to me now, maybe I am having a blonde moment or just a senior moment.
Old Feb 15, 2014 | 5:01 PM
Joe In NY's Avatar
I always go to advanced and buy the 5 quarts of mobil 1 and usually mobil 1 filter for $32. The computer rings up the short filter, if you just back for a truck you get the number for the long filter. Never had a prob with using 5 quarts...
Old Feb 16, 2014 | 10:01 AM
thanks
Do a little home work on the filters, as some even though they fit, are designed different internally, some have a check valve to help keep oil backed up in the system so you don't get a dry start...
As for the oil, once you know what you need you can always put that in, but in an issue where you don't know, go one quart less i.e. 4 or 5... allow the oil to drain down in the pan and check the level after about 15 minutes and add accordingly... if you can, always pre-fill the filter before installing it, this will also help prevent dry starts...
Old Feb 16, 2014 | 11:38 AM
Joe In NY's Avatar
Oh one more thing. That actual oil system, only holds 1 Quart of oil. The last 4 (or 5) quarts is simply there to cool off and just have more oil so that there is more friction modifier and cleaner so that you can actually get 7K miles out of synthetic or 3K miles from conventional.
Old Feb 16, 2014 | 2:31 PM
thanks guys, so used to working on old stuff, such as cars from the 60's
with carbs , no knock sensors, or abs lol
Old Feb 16, 2014 | 4:22 PM
The short filter is the correct one for the 5.3 and 6 quarts is the correct quantity of oil.
Old Feb 16, 2014 | 4:29 PM
Thanks Shark, so 6 qts is good. I have 5.5 and it is all the way up on the holes in dip stick. so I am calling that good.
dirtracer19
Aug 14, 2015 9:10 AM
tufftitty
Jun 3, 2008 6:45 PM
blabontefan
Aug 14, 2007 9:34 AM
