Identifying a Bad Lifter - 5.3
Old Apr 23, 2016 | 12:08 PM
wijeeper's Avatar
Default Identifying a Bad Lifter - 5.3
Hello. I have a 2004 Suburban with a 5.3 Z VIN and 190K. I suspect that I have a bad lifter or rocker due to a non-belt related "chirp/squeak" that is tied with RPM. What is the best method to identify which cylinder/lifter is causing the problem before tearing into the valvetrain and no longer being able to run the motor? Thank you
Old Apr 23, 2016 | 8:08 PM
cleveland63b's Avatar
have you removed the belt and ran the engine to see if the noise is gone? I've seen camshafts make a pretty bad squeak type noise but all in AFM engines which yours is not
