Injector video TBI troubleshooting high idle
Old Jun 9, 2013 | 12:34 PM
DCSCO's Avatar
Default Injector video TBI troubleshooting high idle
'95 k2500 with high idle. 800 RPM with A/C, 1000 - 1100 without. Take a look at the injector stream, does the stream look normal.
[yt]I_ig1Fu9gCA[/yt]
[yt]Uv4EH2icLB0[/yt]
Thanks
Last edited by DCSCO; Jun 9, 2013 at 12:35 PM. Reason: embedding didn't work, added link.
Old Jun 9, 2013 | 12:44 PM
DCSCO's Avatar
Removed and cleaned IAC. Idle went to 1500. Whoops, forgot to plug into harness, idle dropped to 800 w/Air on. Makes me think the IAC works.
MAP, unplugged from harness, no change. Removed vacuum connection and idle went unstable until i plugged vacuum hose.
Looked for vacuum leak with carb cleaner.
High idle/ cold start diaphragm retracts at warm up.
next step is to look at fuel pressure, hope to find a port in engine bay. anyone know acceptable pressure range. Figure about 15psi.
Old Jun 9, 2013 | 12:55 PM
DCSCO's Avatar
As I search the interweb, hundreds of threads for high idle, no reports of success.
Old Jun 11, 2013 | 4:21 PM
bioevolve's Avatar
TPS checked? Maybe a TB cleaning?
Old Jun 11, 2013 | 5:43 PM
DCSCO's Avatar
TB cleaning yes, TPS check, not yet.
in2pro
Dec 25, 2020 11:34 PM
shboutdoors
Apr 1, 2013 4:26 PM
chadzeilenga
Dec 11, 2011 11:32 PM
scootersoffroad
Jan 22, 2010 3:33 AM
