installing a pa rp5 gm11
Old May 4, 2020 | 3:39 PM
Atsui's Avatar
Default installing a rp5 gm11 NEED HELP!!!
im installing a after market stereo into my 03 suburban using the pac interface but i cant figure out how to keep my dvd controls so i can use the headphone in the back seat. its not allowing me to switch the sorce. it stays at radio and when i try to trun the dvd player on the radio and dvd player will play through the speakers at once. i want to be able to change yhe back from radio to dvd while will using my radio in the front
Old Aug 31, 2021 | 11:16 PM
spark43's Avatar
Default Help!
I have this same problem. Were you able to fix this issue?
Old Sep 1, 2021 | 8:43 AM
repairman54's Avatar
The dash radio is the head unit. Once you swap out to aftermarket then all bets are off on controlling the rear unit. All factory sound systems are interconnected and there are always issues installing aftermarket. You may even loose the steering wheel controls and the key / door chimes as they go through the stock radio. Factory radios run through the vehicle computer systems.
Ellibub9
Nov 12, 2017 4:17 PM
mom-of-3
Nov 19, 2014 1:19 PM
capestany
May 6, 2008 6:13 PM
mcrike
Nov 14, 2007 9:56 PM
haidangwa
Jan 17, 2007 9:16 PM
