Intermittent Engine Stall After Hard Brake
Old May 5, 2022 | 4:58 PM
  #21
TishLynn83's Avatar
Default Colorado 2.8
I have a 2006 Colorado 2.8 with an automatic transmission that is shutting completely off when braking, just not every time I use the brakes. It has happened several times as I am coming home. The road is rough right before I turn so I tend to hold the brakes slightly to keep the truck going slower. When I go to make the turn is when I realize the truck has turned off. I've been trying to watch the guages more as I come home and have noticed the RPMs will drop and bounce really low unless I take my foot off the brake. I ran the codes and listed them below. Any ideas?
  • P0449
  • P0030
  • P0017
Old Sep 21, 2022 | 7:19 AM
  #22
Paschall7's Avatar
Default 2015 Sierra
Twice now I've had the engine stall after a hard brake.
Once on I-35 and almost **** myself.
All the older posts seems to be about older vehicles.
Old Sep 24, 2022 | 4:37 PM
  #23
Wavelength's Avatar
Red face Idle RPM
Originally Posted by warthogcrewchief
Thanks. The RPM is right on at 600 RPM. I was thinking about how I wanted to attack this...fuel or air. I know it has a recent (within a year) distributor and plug wires. Plugs, MAS clean, and fuel additive doesn't take much time or money at all to do.
Thanks for the input. It helps to validate what I was thinking.
Try revving in neutral and suddenly release the accelerator. If the engine tries to die, you could try a professional injector cleaning. Cheers. Wavelength.
silver389
Mar 30, 2021 6:02 PM
az-barnum
Cobalt
Aug 7, 2017 5:10 PM
ukrkoz
Sep 13, 2011 6:26 PM
Sharpie Pen
Aug 27, 2011 9:45 AM
chevyDan65
Apr 1, 2010 5:20 PM
