Intermittent gauge cluster help!
Old Dec 21, 2022 | 10:02 AM
DangerRangerEnthusiast's Avatar
Default Intermittent gauge cluster help!
2004 Suburban 1500 LS
Like the title says, my gauge cluster works intermittently.. but when it does function it does so almost flawlessly. It seems like I have a wiring issue, but this is the first Chevrolet ive ever owned. I followed a guide on where the ground locations are for the vehicle and I cleaned those up real nicely for living in the Salt state of Minnesota.
this is what my view normally is when I'm driving down the road. Dead. Toast. No information available, not even what gear I'm in. No fuses, relays, or otherwise are bad in this rig HOWEVER I woke up this morning to head to work and THIS happened
and proceeded to function without issue (minus the temp gauge obviously) for 20 miles before failing again.. what in the heck is happening here to cause this?? All fuses are fine. All relays click and clack, the grounds including the one wire to the back of the engine are fine and dandy, the connector for the gauge cluster is fine, no corrosion no nothing. Because of how it either works perfectly or doesn't my experience on Fords says its not the cluster.. but it's a Chevy soo.. yeah. Lemme know what yall think
Old Dec 22, 2022 | 7:17 AM
Little Jimmy's Avatar
Very typical problem with these GM clusters. There are surface mount resistors in the cluster that become unsoldered. Resoldering them should fix the problem. Youtube is a good source for how to videos. Or if you aren't comfortable soldering, then these can be repaired $100 / 150. Anti-theft system prevents just swapping out the cluster with another, unless it is reprogrammed. Cheaper to repair existing.
lugnutz24
Feb 17, 2015 10:05 AM
bigge31566
Aug 13, 2013 1:10 PM
chevyc1500
May 10, 2013 4:01 PM
joshr84
Feb 11, 2012 6:54 PM
rjhewitt78244
Aug 19, 2011 11:23 AM
