Intermittent Wipers Not Working - HELP!
Old Feb 28, 2026 | 7:23 PM
Knick2011's Avatar
Default Intermittent Wipers Not Working - HELP!
Hello all - this is my first post on the forums here, joined to hopefully get some help sorting out an issue.
We have a 2008 Suburban LTZ, have owned it for about 2 years / 30k miles (currently 120k). The intermittent wiper settings never worked properly. The spin-down function to just wipe once works, as well as the 2 constant (2 fastest) speeds. The intermittent settings have always had a mind of their own, sometimes not wiping at all, then randomly starting and wiping at varying intervals.
First i changed out the wiper switch on the column with an OEM part - no luck there. I have now changed out the wiper motor itself (actually the whole linkage/motor assembly, also OEM) and the issue persists.
I have read some about BCM failure and it causing some strange issues. I am hesitant to attempt that but it may be my next shot.
Has anyone else had any similar issues with their intermittent wiper settings?
I appreciate any help you have to offer. Thanks!
Old Mar 1, 2026 | 6:09 AM
Knick2011's Avatar
Originally Posted by AlexMonroe75
Dude, I had a similar issue with my 2022 Silverado LT. Turns out it was the wiper switch itself, was faulty and needed to be replaced - pretty pricey but solved the problem for good.
I appreciate the reply. I have already replaced the wiper switch, as well as the wiper motor. Not sure where to turn from here....
Old Mar 1, 2026 | 8:55 AM
a55bruce's Avatar
Here's the Wiper Switch Schematic
Check the switch by unplugging the connector and measure the resistance between terminals M & N.
I'd compare the old switch with the new one. No resistance change indicates a bad switch.
With the switch connected, measure the voltage between M(Tan/Blk) & N(Lt Blu) checking for a change at each speed setting.
If the voltages change then you may have a bad BCM.
Old Mar 2, 2026 | 8:24 AM
Cusser's Avatar
My 1970 and 1971 VWs and my 1998 Frontier do not have intermittent wipers by factory design/choice, and they do fine.
Old Mar 2, 2026 | 8:29 AM
Knick2011's Avatar
I appreciate the help! I have a BCM ordered, I will reply back here once I confirm the fix. I have questioned the BCM failure or issues before - random door open warning popping up when driving, lock cycling randomly. Cruise control would sometime not engage, which was recently fixed with a break pedal switch.
Hopefully the BCM will do the trick!
Old Mar 2, 2026 | 8:30 AM
Knick2011's Avatar
It could be defined as a luxury option.....tell that to my wife!
Jennifer Gaines
Apr 15, 2021 9:02 PM
Bhicks
Nov 21, 2018 8:00 PM
jordi
K5 Blazer
Aug 17, 2018 11:46 AM
03rubicon
Jun 15, 2010 6:11 PM
