Jack recommendation
Old Jan 3, 2024 | 6:27 AM
CaughtInCeilingFan's Avatar
Default Jack recommendation
What Jack does everyone here use? Asking because I've got a Black Jack 2 ton from Walmart. I think its maximum height is like 13 ½ inches, or something like that. I put it on the frame to lift it and the tires wouldn't come off the ground.
Or is there another location I should place the Jack? I don't want to put it somewhere that isn't strong enough to support lifting. I think I have a couple of spots I can use on the rear end, which I've seen people use as Jack points before.
01 Suburban LS, factory ride height
Old Jan 3, 2024 | 7:19 AM
It may not be recommended, but I put a block of wood between the jack and the frame and it works. Been doing this for many years with no problems. Of course I also use a jack stand.
Old Jan 3, 2024 | 8:30 AM
Cusser's Avatar
I have - and like - the 3-ton low profile/long reach 3-ton floor jack from Harbor Freight.
https://www.harborfreight.com/3-ton-...ray-70482.html
Old Jan 3, 2024 | 7:54 PM
I always put something between the jack or the jack stand and the frame such as a piece of wood or thin piece of rubber to prevent steel to steel contact which is pretty low friction.
Old Jan 4, 2024 | 8:19 AM
Cusser's Avatar
I use a block of wood (4x6)
>BILT4 IT<
Jan 15, 2022 4:21 PM
1chrismunn
Jul 18, 2013 5:21 PM
romadrome
Feb 3, 2013 5:26 AM
aris_unlimited
Apr 29, 2012 1:07 PM
2002chevyman!!
Mar 3, 2012 11:24 PM
