Jump seat replaced with center console
Old Jan 8, 2012 | 8:30 AM
dishawcues's Avatar
Default Jump seat replaced with center console
I removed the center jump seat on my 07 Suburban LS. The Center console was very easy to replace but the unit I have has a radio, cig. lighter in the rear, in addition to a USB port and another cig, lighter inside the arm rest compartment. My question is, the radio has a Bose Amp mounted with a wiring harness, Can any of this be hooked up? I don't necessarily care about the radio hook up but would really like to get both cig. lighters wired as well as the USB port
Old Jan 8, 2012 | 10:27 AM
ChevyFreak's Avatar
I highly doubt the rear radio controls will be able to be hooked up. I could be wrong about that, but I don't think it will be an easy job to get that done. However, you mentioned your Bose amp has an available wiring harness. Does anything fit into that harness?
The USB port would only be useful if your radio head unit has a USB plugin. This is probably not the case, unless, of course, you have replaced your radio recently. This console must be from a newer vehicle, as the USB was not an option until 2009.
The two in car power plugs (cigarette lighters) should be able to be hooked up, I just can't tell you exactly how. It would simply be a matter of connecting a proper power source and ground. There must be some wires somewhere for these plugs. See if you can find the wires and trace them back to their source. That way, you can get an idea of what you are working with.
As I stated before, you mentioned your Bose amp has an available wiring harness. Does anything fit into that harness? Do any of the wires match up? Let us know how you make out. Good luck!!
Old Jan 8, 2012 | 11:54 AM
+1, I'd check to see what harnesses are in that area, the power outlets are likely there....
Old Jan 11, 2012 | 6:23 AM
dishawcues's Avatar
Here is a pic of the wiring harness the smaller male plug is directly connected to the cig lighters. the big connector is connected to the Bose amp. any chance there is a connector somewhere under the carpet.??Jump seat replaced with center console-img_0449.jpg
Old Jan 11, 2012 | 9:11 AM
SabrToothSqrl's Avatar
Default Usb
USB was 2010, not 2009.
your best bet for the USB would be to use it for only a charging point.
find a 12v to USB charger, then get an extention for it, and use the female end of it for that port or wire it up manually... then that port can be used to charge phones / headsets / etc.
Old Jan 25, 2012 | 9:32 AM
05Z71Burban's Avatar
What did you do with the jumpseat? Im looking to replace my console..
dacapeman
Sep 20, 2011 3:25 PM
Danistheman1234
May 18, 2011 10:49 PM
Danistheman1234
May 14, 2011 8:55 PM
Felix
Jul 10, 2008 6:29 PM
TahoeG8R07
Aug 2, 2007 12:24 AM
