Knock sensor problems
Old Jun 21, 2010 | 7:14 PM
cooter26's Avatar
Default Knock sensor problems
2004 Suburban 5.3
Check engine light came on a while back and i changed both sensors and harness. I also removed the rear foam and put rtv around the plugs like the recall instructions said. I used the expensive metal snap in intake gaskets and torqued everything to spec. Not more than 200 miles later the light came back on, i keep reseting it but its driving me nuts and it was not cheap or easy to replace it the first time.
Thanks
Old Jun 21, 2010 | 8:24 PM
dh1's Avatar
dh1
Assuming you pulled the codes from the OBD and you are getting the same knock sensor issue? Or is it possibly a different error code?
Anyway, it is entirely possible that you got a unit that was bad out of the box. Another possibility is another problem is causing the knock sensor to indicate out of spec.
Old Sep 14, 2011 | 7:11 PM
joaquin's Avatar
hey everyone! i have a gmc sierra it has a 5.3 enginee and am having the same problem with the knock sensor i have done everything you guys have done and the light still come back on. i was wondering if you guys did something different or something new to fix the problem? can the air filter intake affect the knock sensor?
jdog
Dec 10, 2024 12:11 AM
jffgin
Mar 10, 2008 2:32 PM
desilverado
Mar 24, 2007 4:10 AM
jamesdal7
Jul 18, 2006 11:11 PM
