Lane drift alert
Lane drift alert
Hello , can anyone please offer some advice . I own a 2017 Suburban LT (loaded) . I purchased in September 2017 . This is my second one since body change in 2015 . Anyway my Suburban would Either beep or the seat vibrate if the sensor was able to read the
lines on the road . My 2015 did it and I’m aware it can only do one or the other beep or vibrate. My 2017 beeped whenever I crossed a line a bit or the seat vibrated again whatever I set it for . It works from day I picked up 9/5/2017 until one day on the way home from a dr appointment it just stopped in Feb 2018 it’s been to the service center countless times called GM who tells me “ it may or may not work depending on conditions! I get it I know when it won’t work . But this worked for 6 months then stopped! I switched dealerships they had in 2 times can not find anything wrong and GM told them to tell me to refer to the manual! The other audible or vibration warnings work . So when I back out of driveway it does beep or vibrate if a car is coming in either direction . It beeps when I back up and get near something. It did work whenever I drove . I’ve had people ask what is that beep while I wound use Bluetooth. I would greatly appreciate any advice. Thank you
Just so I understand the question here, is the lane departure detection is not working correct? or is it the alert that it sends to the driver not activating the way you expected i.e. not beeping or not vibrating?
Lane drift alert
Hello and thank you for responding. The audible beeps and seat vibrating stopped working . It shows the green colored car on display , it turns amber if I drift and it will gently bring me back into lane but no beeps or seat vibrate as it used to do for the first 6 months
I would suggest turning both response options off, then perform a key cycle and try turning them back on and see if that does it, if not I try a reboot, disconnect the battery for a couple of minutes and see if it resets..
If that doesn;t do it , you may need to get into the dealership and see if something has happen with the programming.
I have experienced the same issue with my 2017 Suburban Premier. I loved the Lane Departure Alert/Warning, specifically the seat rumbling. When the dealership "updated" my software this spring, this safety feature was deleted. I've written Executive Customer Service, who gave me a list of reasons why it wouldn't work as an example, snow covering the road (duh!), as well as one to Mary Barra, the CEO of GM, and no one from her level has bothered to reply. Has anyone else had this problem? Did you get it resolved? If so, how? TYIA, JBA
From everything that I now know, it appears that GM has arbitrarily deleted a safety feature that I paid for.
If any Chevrolet Suburban owner/reader has lost the lane departure warning feature, please report this issue to the National Highway Transportation Safety Administration at https://www.nhtsa.gov or www.safercar.gov. This governmental agency is collecting information on safety issues and needs to know more about this matter in Suburbans.
IB Jason
Newsletter Archive
February 12th, 2018 3:48 PM
IB Cristina
Newsletter Archive
December 5th, 2017 9:32 PM
