Lane drift alert
Old Aug 20, 2019 | 1:01 PM
Anthony68's Avatar
Default Lane drift alert
Hello , can anyone please offer some advice . I own a 2017 Suburban LT (loaded) . I purchased in September 2017 . This is my second one since body change in 2015 . Anyway my Suburban would Either beep or the seat vibrate if the sensor was able to read the
lines on the road . My 2015 did it and I’m aware it can only do one or the other beep or vibrate. My 2017 beeped whenever I crossed a line a bit or the seat vibrated again whatever I set it for . It works from day I picked up 9/5/2017 until one day on the way home from a dr appointment it just stopped in Feb 2018 it’s been to the service center countless times called GM who tells me “ it may or may not work depending on conditions! I get it I know when it won’t work . But this worked for 6 months then stopped! I switched dealerships they had in 2 times can not find anything wrong and GM told them to tell me to refer to the manual! The other audible or vibration warnings work . So when I back out of driveway it does beep or vibrate if a car is coming in either direction . It beeps when I back up and get near something. It did work whenever I drove . I’ve had people ask what is that beep while I wound use Bluetooth. I would greatly appreciate any advice. Thank you
Old Aug 20, 2019 | 3:10 PM
Just so I understand the question here, is the lane departure detection is not working correct? or is it the alert that it sends to the driver not activating the way you expected i.e. not beeping or not vibrating?
Old Aug 20, 2019 | 3:55 PM
Anthony68's Avatar
Hello and thank you for responding. The audible beeps and seat vibrating stopped working . It shows the green colored car on display , it turns amber if I drift and it will gently bring me back into lane but no beeps or seat vibrate as it used to do for the first 6 months
Old Aug 25, 2019 | 11:21 AM
I would suggest turning both response options off, then perform a key cycle and try turning them back on and see if that does it, if not I try a reboot, disconnect the battery for a couple of minutes and see if it resets..
If that doesn;t do it , you may need to get into the dealership and see if something has happen with the programming.
Old Sep 6, 2019 | 4:49 PM
benign's Avatar
I have experienced the same issue with my 2017 Suburban Premier. I loved the Lane Departure Alert/Warning, specifically the seat rumbling. When the dealership "updated" my software this spring, this safety feature was deleted. I've written Executive Customer Service, who gave me a list of reasons why it wouldn't work as an example, snow covering the road (duh!), as well as one to Mary Barra, the CEO of GM, and no one from her level has bothered to reply. Has anyone else had this problem? Did you get it resolved? If so, how? TYIA, JBA
From everything that I now know, it appears that GM has arbitrarily deleted a safety feature that I paid for.
Old Sep 22, 2019 | 10:11 AM
benign's Avatar
If any Chevrolet Suburban owner/reader has lost the lane departure warning feature, please report this issue to the National Highway Transportation Safety Administration at https://www.nhtsa.gov or www.safercar.gov. This governmental agency is collecting information on safety issues and needs to know more about this matter in Suburbans.
Old Nov 23, 2021 | 10:16 AM
Tom Baca's Avatar
I own a 2018 Tahoe LT RST and this is exactly what I have been experiencing. I know it worked a few weeks ago, but now I get a "lane assist" steering nudge but no sensible vibration when set to that OR an audible beep when set to that. As far as forward collision braking and headsup signal, that works very spotily. I am going to try to disconnect the negative terminal of the battery as one of the commenters advised and see if that works before taking it in. The only issue with battery disconnection is all of the memory functions as far as seating, radio preferences etc will be reset as well as the clock etc.
Old Nov 23, 2021 | 10:22 AM
Tom Baca's Avatar
How do you perform a key cycle?
Old Jul 15, 2022 | 3:46 PM
L8wine's Avatar
New User
Awaiting E-mail Confirmation
Did anyone ever find a fix to this? I have a 2019 Chevy Traverse, that my lane assist beep quit working. thx
IB Cristina
Newsletter Archive
Dec 5, 2017 9:32 PM
Miami Son
Aug 7, 2017 10:21 AM
Bald_gy
May 29, 2017 7:41 AM
wyep
Jan 3, 2017 12:24 PM
