Leak 2010 Tahoe LTZ
Old Aug 29, 2015 | 8:35 PM
Kan0wat's Avatar
Default Leak 2010 Tahoe LTZ
Water leaking from foward dome lighting and don't know where it's coming from. Any advise?
Old Aug 30, 2015 | 9:56 AM
Do you have a sun roof? (the drain tubes run to both driver and passenger pillars)
Do you have rear AC? (not as likely a cause of leak but plausible because the venting runs through headliner area)
Do you have a roof rack?
Don't rule out the shark fin antenna (very likely cause)
These are potential leak points, have you pulled the lamp assembly to check for the leak?
Old Aug 30, 2015 | 4:48 PM
Kan0wat's Avatar
Took down the head liner and cannot trace any water leak. Used compressed air to blow out the drains. Hoping for the best.
zzzoom
Jan 7, 2024 2:24 PM
SoftailRdr
Jan 2, 2019 7:38 AM
180Custom
Dec 17, 2010 6:56 PM
jdmaag
Sep 23, 2010 9:51 PM
labsr4me
Aug 2, 2010 10:10 PM
