LED conversion
Hello,
2007 Suburban 1500.... I am looking to replace my entire headlight assemblies due to fading. Since I am pulling them apart I'd like to replace all the bulbs with LEDs for better brightness. While researching I have found many H11 bulbs that appear to have a clearance issue when installing in the suburban. Do you have a recommendation that will not have this clearance issue?
Any recommendations on the headlight assembly itself? I like to keep it stock in appearance.
THanks in advance!
THanks in advance!
Are your headlights fading from the inside or outside? I see what looks like fading on mine, but it appears to be more from heat from the inside than sunlight. Especially given that it's lived in a parking garage for most of it's daylight life.
Anyway, I replaced my fog lights w/LED, and although the lights were super bright, they never lit the road as well as the OEM bulbs did. I went back to the original old school lights. For lights, of any type, to work correctly, the housing must support them. I've never liked the bling look of some of the after market ones, and they seems to either blind other drivers or not give enough light...
your call, but I found the OEM lights on the 07+ are pretty good stock.
Here is what they look like. Maybe going with better halogen bulbs might be the answer. My brights are fine I was just trying to get better output on the low beams...
If you do not want to experiment with the LED upgrades, you may just pick a set of Sylvania Silverstar bulbs. From my experience, this is one of the best halogen headlight bulb options available today. Below is the link to these bulbs foe the '07 Suburban.
Sylvania Headlight Bulbs at CARiD
Now, as for the headlight assembly recommendations. If you want to stick to the OE appearance, there are pretty much 2 options we suggest. You can pick OE-style headlights (you will need to pick passenger's and driver's side separately). They are made not by GM, yet feature exactly the same appearance and connectors. Check out this link to view the options.
There is another alternative for you. If everything is fine with the stock lights except of the lenses, you can pick a set of Euro headlights. These come without bulbs and wiring, so you pretty much re-use what you've got from stock. Here is the link to view these headlights. Here you see the price for pair, and pretty much get the new headlight shells.
Hope this info will be helpful for you.
Feel free to contact us if you have got any questions.
Maybe I can help you out a bit. I have some basic T12 fixtures in my basement that were here when we bought the house, and after some issues with the ballasts, I plan on just taking the ballasts out and replacing the tubes with LED tubes instead. I don't know if they will be of any help, but I will gladly give them to you if you still need them. I found online some explosion proof LED flood lights, and they seemed so cool. I have to talk with someone to see if they would be good for my basement and If so, I am getting them as soon as possible.
