Left Signal not working
Old Jan 20, 2007 | 6:03 PM
gamato's Avatar
Default Left Signal not working
I have a 1999 Tahoe, and recently the left rear signal isnt working. I thought it was a bulb, because when I try the left signal, the flasher clicks really fast like a bulb is out, so I replaced it, and it still doesnt work. The right signals are fine as well as the front left. I thought maybe the flasher was bad, so I replaced that too and still doesnt work. Can someone please help. Thanks.
Old Jan 20, 2007 | 7:10 PM
doo600's Avatar
Default RE: Left Signal not working
Make sure it's the right bulb and try another. Check the contacts in the socket to make sure they are clean and making a good connection. Make sure the wiring is in good shape.
Old Jan 20, 2007 | 8:17 PM
Check the voltage at both contacts with turn signal flashing. You didn't mention if the left rear taillite and brake lite work. I don't know if either are used for the turn signal but if they are and they work, then you've isolated the problem to the turn signal system and not the bulb/socket.
Old Jan 21, 2007 | 1:06 AM
engine2's Avatar
ORIGINAL: gamato
Take the good bulb that does work for sure and switch sides to be sure its not a bad bulb or incorrect side
Yogi
Dec 12, 2021 6:25 PM
carpetogie
Oct 5, 2014 7:05 PM
RomanGuzi
Oct 2, 2011 11:40 AM
derrik38
Jun 13, 2007 9:09 AM
derrik38
Jun 4, 2007 10:02 PM
