low oil pressure warning and 0 oil pressure on gauge
Old Sep 15, 2013 | 5:29 PM
not_a_car_dude's Avatar
Default low oil pressure warning and 0 oil pressure on gauge
I drove my 2003 Tahoe this morning, no problem. Went to start up this afternoon. Acted like it had a weak battery, but then started up. I hear an odd "ticking" noise from under the hood and the "OIL PRESSURE LOW" warning is on the dash. Also, the oil pressure gauge is reading zero. I shut off the engine and tried it a little later. Same results. Oil level is in the good range.
I am not a DIY kind of person. The mechanic that I have used in the past is about 10 miles from the house. Am I safe driving the vehicle to the mechanic, or should I consider having it towed?
Old Sep 15, 2013 | 5:35 PM
Welcome to the forum.
Since your oil level is OK and you're hearing a ticking noise, it sounds like you have no oil pressure as the gauge is telling you. Unless someone else has a better idea, I'd recommend having it towed.
Old Sep 15, 2013 | 7:02 PM
Joe In NY's Avatar
maybe you have sludge build up and it happened to clog the intake screen? also, hard to start doesnt sound good...
Old Sep 15, 2013 | 7:12 PM
Default started ok the second time
It actually started ok then second time that I tried it, as well as when I had a friend listen to it. The manual said "stop when next safe to do so and have it looked at by a mechanic". I don't know if this means STOP NOW! or if it means "ok to drive to the shop".
Old Sep 15, 2013 | 7:41 PM
RichC10's Avatar
Drive or not?? It depends...... At 10 years old, the damage is probably already done and you need a new motor either way. Even if they fix the oil pressure problem, it will probably spin a bearing soon, because of the damage already done.
Subur2023
Jul 29, 2021 4:51 PM
J C Smith
Aug 29, 2019 8:32 PM
Crew Cab Kevin
11
Jul 1, 2012 1:52 AM
98_454
Jul 4, 2010 10:27 PM
r970
Jun 3, 2007 8:16 AM
