Lowering with Autoride
Hello everyone,
I just purchased a 07 LTZ and like all was disgusted with its rear in the air. So to handle this I went with the folks over at DJM. I purchased the 2/3 kit and installed it today. The front dropped like it was supposed to but he rear is up in the air more than ever now. It appears that the auto ride is keeping the bags inflated. I've looked around to see if there was some sort of reset procedure but have found nothing. I've read on a post prior that some "bending" of the sensor arms are required?? Odd that DJM would not enclose a set of properly modified sensor arms. Any thoughts on this would be greatly appreciated, I may have to resort to making a set of new sensor arms.....ugh R&D what does that mean???
RE: Lowering with Autoride
Can you just bend them effectively shortening them? Recall another post where someone got a kit that had new, shorter sensor arms.
I may have to resort to doing just that. Going to disconect them first and move them manually to see where exactly they sensor begins to tell the air pump when to start leveling the vehicle. I'll keep you posted.
There was a member that put a McGaughy's on his Friends 2007 Denali. He ran into the rear height issue. I actually think he over bent them and it sat to low.
I am 99.9% sure you need to bend yours to get that azz end down.
Ok so here's the fix. When lowering the "Autoride" you do in fact have to modify the two height sensor arms. I tried bending one and it was about as backyard as you could get, so I got a new one from the dealer. What I ended up doing was figuring out the % I dropped the vehicle wich was 22% of normal ride height. Than I cut 22% off of the two sensor arms. This is @ 1 inch off of the arms. To do this remove one of the plastic sockets off of an end and cut back 1 inch, make sure to leave the fat part of the metal shaft. Add some glue and press it back on. Test drove the vehicle no warnings, added weight to make the pump come on i.e. @ 900lbs and the compressor came on to level the ride. Get to lowering those LTZ's
P.S. The lowering kits for the LT's will work for the LTZ's.
The ride is great I had some pics but the files are to large 1.3megs lol. Right now I'm putting the exhaust on and about to do another dyno before the installation of the headers. After I finish I will get some pics up for ya.
mattintc
August 14th, 2012 11:36 AM
