MAP Sensor Question
Old Dec 29, 2011 | 6:59 PM
Unknown1329's Avatar
Default MAP Sensor Question
Hi I have a 1995 Chevrolet Suburban with 201k on it. I posted on here before a problem with my rpms surging. I found the fix or so I thout by replacing the throttle position sensor. Now it is doing it again and a friend who is a "beginner" mechanic said to look into the map sensor. What are symptoms of this going bad and how hard to replace? At low rpms it will randomly drop to almost stall like it is starving for gas then surges back up and is normal then goes and does it again. If I really stomp on it it will run fine but lower engine speed it doesnt run right. I'm constantly thinking I'm gonna stall out at a red light so I stopped driving it. We just got our first real snowfall today and I need it again.
Old Dec 30, 2011 | 4:16 PM
WHISKEY DAMAGE's Avatar
To me it sounds like fuel pressure! Check ur presure regulater!
And have u changed your fuel filter?
Old Dec 31, 2011 | 3:06 PM
I have changed fuel filter just recently actually.
Old Dec 31, 2011 | 6:31 PM
I would check the IAC or Idle Air Control valve, it controls the idle at well idle conditions like at a stop...
Might also want to check for any vacuum leaks...
M800
Oct 30, 2013 1:00 PM
kyina
13
Jul 12, 2011 9:28 AM
frgazda
Dec 3, 2008 11:56 AM
gungfu01
Feb 9, 2007 11:30 PM
maddmatt16052
Dec 1, 2006 6:54 PM
