Menu, fav, and info button not working
I just bought a 2010 tahoe. I'm having problems with three buttons ; menu, favorites and the info button. It works sporadically. I notice it will stop working after I use my iPhone on the mp3 reader or DVD player. If I press the buttons a few times it starts working again. The dealer said it would be $500 to replace the oem unit. Any suggestions?
You could try "rebooting" everything... disconnect the battery for several minutes and see if it resolves the issues... if not I would suspect something is up with the radio....
You might also try a different interface cable from your pod/mp3 player, some cheap cables can allow interference or be poorly assembled and cause strange things to happen...
Limitby9
March 24th, 2021 11:43 PM
